I am trying to make a memorial rose for a friend that has the persons name as the stem. I have the rose I want and the font for the name I want but when I place the two together I still see the original stem lines. How can I eliminate parts or the stem lines to not interfere with the name?https://easel.inventables.com/projects/-oT4n-WzcBnld4YkkbFtsQ
That said. You can add a shape, set it to 0 depth and then use the layering to put it in between the rose in the back and the name in the front.
Select the shape, right click >move backward. Or select the name. Right click, move to front.
I tried that but then when I want to carve the rose I have to have a depth to cut and when I do it will interfere with the name…
I made the project public I hope it works now
Thanks
Thank you very much that does help me with what I am looking at doing.
