Hello, I was wondering if there is a way to add your hold downs to the material so that way when it easel does the gcode it can like go around your hold downs maybe?
you can get easel to Raise up and avoid the clamps, OR you could use Center as the zero, zero position and that tends to help with avoiding clamps…
For the Raising up part, go go Machine>General Settings and you can edit the Safety Height which effects the moves within the carve portion, AND the Origin Safety Height which only effects the First and Last move of the carve. this one is intended for clamp avoidance.
and here’s how to use center as 0,0
and in case this is a 3d project:
