Holes not getting correct measurements
Hi All,
I have performed tightening of the belts, ran a test to see if my stepper motors are indeed covering the correct distance and all seems ok. 500mm model
When I cut with Easel here are my test results:
10mm holes (not not all perfect, average diameter:
Inside Cut 9.4mm
On the line 12.6 mm
Outside Cut 15.9mm
Fill 9.4 mm
10mm Square
Inside Cut X 9.5mm Y 9.2mm
On the line X 12.5mm Y 12.3mm
Outside Cut X 15.8 mm Y 15.6 mm
Fill X 9.5 mm Y 9.3 mm
To me this seams the Y axis is obviously missing a few mm vs the X however, I’m still not getting my even 10mm.
I’m not expecting pin point accuracy, however, Once I know how my machine is working I can compensate in the drawings so I get closer.
Any ideas?
Thank you
V
Cutters are not exactly the dimensions stated. They have a tolerance associated with them and generally are a tad undersized. Unless you measure the true cutting width and use that as your bit size, you’ll be off by a few tenths of a mm like you are.
Getting 10.2mm now on inside cut. Think
I’m happy with that :). Thank you
