Perfect!
is this the sheet of aspen that you get ?
http://m.homedepot.com/p/1-4-in-x-4-ft-x-8-ft-Aspen-Osb-Sheathing-Board-300985/100025804
ok itâs what homedepot called common wood , I was just woundering what aspen was.
thanks Phil
Iâm not surprised. Those are great! No offense but I like those more than the deer.
Unwrapped Hersheyâs KissesâŚ
I thought it was chocolate yogurt for so longâŚ
you sir are my hero! That movie is a classic and soo beautifull
Phil⌠How do you change the radius on your designs to match the bit you are using, is this done in Easel?
Any chance you have those reindeer designs in svg (or dxf or similar)? I generally use Vectric software, and as Easel doesnât allow exporting yet, itâd be very helpful.
Thank you sir - you are a scholar and a gentleman!
If anyone is using Vcarve, here is the CRV file. I only have tools paths created for the first board
.pooping raindeer.crv (777.5 KB)
I noticed that and adjusted the drawing in Vcarve, so the cut out goes beyond the profile cut.
Could a X-Controller order be forthcoming?
Yep. I still need to make the connection from head to pusher.
Allen, do you run all the tool paths as one Gcode file? or run them separate?
Since I only need one tool (.25 compression em) all the tool paths are in one gcode file
Even though my design skills are severely limited, I have VCarve Desktop and love it.
