I have just got my 1000mm setup with the audrino and g sheild. When i go to calibrate online it really does not do anything. First it says homing and then it moves just a little but the screen does not say anything is wrong. I was under the impression that it would run to each limit switch??
Then it says calibrate and asks for size and threaded rod or acme screw. Spindle and so on and when you put in all the information it just takes you to a test carve which is not coming out good. The dot over the I is out of place and the letters are wavy…?
Any suggestion?
