Homing cycle stuck during Easel setup
I assembled my 750mm X Carve and everything is going well. Now that I am trying to configure the machine in Easel I have run into a problem with the homing setup. The z axis moves up to the limit switch and stops. Then it backs up but not far enough to release the switch and stops. Then nothing moves and the machine just sits there.
I have checked the wiring on all the switches. Nothing is shorted, the voltage at the Normally Open pin on each switch is 4.85 volts when the switch open and 0.0 volts when the switch is closed.
Any ideas?
Thanks!
Check your setting for $27 - Homing pull-off. You may have to increase this value if the limit switch is not being cleared when the machine backs off after initial contact is made.
{:0)
Brandon Parker
Thanks @BrandonR_Parker! That was it, I changed it from 1mm to 5mm and we are moving along.
Fantastic!!! I’m glad you were able to get it working.
{:0)
Brandon Parker
