Is there a way to home the X-Carve without turning the controller off and then on or without unplugging the USB cable and reinserting it.
Through Easel?
Open the machine inspector, in the console type $H
You can also go under the Machine drop down I believe there is a button that shows when you are hooked to the controller that will show “home the machine”
