Homing failed message
Brand new machine. Worked perfectly for the test carve then put a piece of wood on selected one of the icons in Easel to carve and the machine won’t home…“Homing failed message”?
There’s nothing unusual with the clamping or anything … Machine is clean as a whistle. I’m at a loss??
Any help would be appreciated.
Did the machine move at all before you received the error?
If one of the homing switches was already pressed when you went to home the machine, you’ll receive an error.
Thanks. All sorted.
The bracket holding the belt for the Y-Axis was loose. Possibly during transit to Australia maybe?
Was a bit surprised after only 5 minutes of operation but no problem all is fine.
Took the table off … Found the problem. The machine is now working beautifully.
Thanks
