Homing Issue
Still have homing issues, everything is working but the Y switch gets crushed when sending to zero in UGS. Do these settings look correct? I tried redoing the setup in Easel but it never seems to do all 3 axis. Here are my setting, if someone can match them to there’s with a 1000x1000 unit.
$0=10 (step pulse, usec)
$1=0 (step idle delay, msec)
$3=3 (dir port invert mask:00000011)
$6=0 (probe pin invert, bool)
$10=3 (status report mask:00000011)
$11=0.050 (junction deviation, mm)
$12=0.002 (arc tolerance, mm)
$13=0 (report inches, bool)
$20=0 (soft limits, bool)
$21=0 (hard limits, bool)
$22=1 (homing cycle, bool)
$100=40.000 (x, step/mm)
$101=40.000 (y, step/mm)
$102=188.976 (z, step/mm)
$130=790.000 (x max travel, mm)
$131=790.000 (y max travel, mm)
Does it home ok in Easel?
It homes at Z then just says ok you’re all set on the screen
Here is mine.
Brian,
Looking at yours and Alan’s settings, they are identical.
It may be time to get simple. I made this mistake and found it when I slammed my Y axis upon homing. I was on a wild goose chase until something made me look closer at the switch itself.
Are you wired to the switch correctly? In the main image on the instruction page, it shows one switch with the ground soldered to the connection opposite the pivot point of the lever. Mine wasn’t. once I moved the ground to the pivot point contact, all was well. Some of the goofs on this thing are annoyingly easy to make.
regards,
Joe
