Is there a command to home the Z-axis without moving X or Y axes?
Not to home but to probe individual axes.
The command is G38.2 + code for search distance & speed.
You want to home or just raise to home position?
I just want to raise it to the top without moving in X or Y directions.
G53 G0 Z-5
Moves the Z to 5mm below the limit switch off you work in mm.
To be safe:
G21 ;mm mode
G90 ;absolute mode
G53 G0 Z-5
Thank you very much, Neil. Much appreciated!
