I’m a newbie and finished my first practice carve. How do I manually move the spindle up and away so I can remove my work piece? I can’t seem to find any arrow buttons or anything like that like there is when you find your zero point in the carve set-up.
Thanks for any help you can provide.
Tony Hirschenberger
I raise my bit and turn the X Controller off. After a short wait, I GENTLY push the carriage back out of the way. I was told that with the power off and a slow, gentle push, this was okay. Am I risking damage?
I use a Mac Mini. I run a program called QuicKeys. I programmed the G28.1 and G30.1 to move the spindle to specific locations. When a carve is complete, I simply press F2 or F3 to quickly move it out of the way, to the back of the carving area.
Easel allows you to enable beta features, etc in the machine settings, why not have an option to assign a specific key or keystroke combination to a GRBL command? ie G28 or G30. Basically, giving us macro commands like other programs do.
