I have a portion of a carve that I have already designed but I am having an issue rounding of these edges here? How would I do that? I have tried to combine a rounded edge into the design but Easel keeps doing the opposite of what I want it to do.
Help, My brain is Vapor locked right now!
Click on design element you want rounded corners on then click on edit points (bottom of cut tab) and then click on the nodes (little circles) on the edge you want round and then click on curved, use the handles to malipulate the curve to desired edge.
You can set it as fill then create zero depth circles and combine as another option, then go back to outline after you combine
This worked perfectly. I clicked on each node (one upper, one lower) and clicked curved. It curved it without any manipulation. Thank you!
