How do you flip an object?
. how do you flip 90*
I think there is a rotate button in the Properties window that pops up when you select an object.
I’m not sure the question but if you select an item in Easel, there is a long line with box on the end that will enable you to rotate that layer. If you want the whole design to move, make sure you select all before you rotate anything…
To flip, select the object and choose to flip in the Edit menu, to rotate to a precise angle select the object and in the Shape palette type in the angle you want and hit tab or enter.
