How do you move the X-Carve a set amount to check calibration
I would like to check my calibration and have watched a video by Manhattan wood project that has all the detail with the exception of how to move the bit 700 mm. Do i put this into Easel somehow under Machine Setup?
I have figured this out. I assume everyone else is just putting this into easel, click CARVE then edit Step Interval under Machine Settings
Use either Universal G-code sender or PicSender. You will be able to put in a jog distance and move it that way for any of the 3 axis.
Charley
