How high is x carve
I Have build a work table too my 1000 mm X Carve (i did not assemble the X Carve yet)
I am going too install a monitor stand back on the table , and wants the stand bee so high so the monitor
can slide over the highest Point off the X Carve,
so my question , How high is the x carve going too bee, wtith the spindle include ? (quiet cut spindle )
331mm or 13.0315in from the bottom of the waste board to the top of the spindle mount.
x-carve.pdf
perfect,
thats what i looking for :grinning:
I would suggest building in a couple of inches, in case you want to put a bigger spindle in or increase the cutting height at some point.
Also are you going to add any dust collection? If so your hose might also interfere with it. I had to alter where my monitors were going to be because of the hose to my shop vac.
Uploading 01761195789d3cd78badcaa9e86b3ff08f44c958d2_00001.jpg…
