How tight should the belts be set. I just finished assembling the mach and I notice that when I try to run it that it makes a rubbing noise, like the motors are catching on the rail
Hi Tim,
I used the search function to find the following for you:
https://discuss.inventables.com/search?q=Belt%20tension
Hopefully one of those links will help you find your answer.
Use a fish or luggage scale, center of the belt, 1 inch deflection, no more than ~4lbs. Assuming 1000mm.
Also, check the idlers and pulleys, make sure the belt is centered and not rubbing either edge.
would the belts being to tight cause a skipping
or would the v wheels be too tight
ok, thank you
Yeah, typo, I meant to say 5lbs.
