How to add a Spoilboard/Flattenning Bit in the X-Carve Pro
I’m trying to find a way to add the Flattening bit to my tool box? I don’t see the type on the drop down? Its the Amana/Inventibles Bit that came with my X Pro. Any suggestions?
Thanks in advance!!
You have to enter it as a custom bit in the add bit section.
This would be entered as an Endmill… you can enter as any of the subtypes of endmill, that doesn’t actually matter, but for consistency I would add it as a “straight” bit and then enter the cutter width and an appropriate name as desired. and you’re done with the bit entry… you will need to ensure the cut settings are entered as well though as the defaults are likely not appropriate for surfacing.
Thank you!!!
