Thanks in advance, Hi I need to add some bridges to a cut out I am doing, how do I add bridges in Easel PRO
Thank you
Thanks Steve much appreciated
Aarhh I see you have to select cut on shape path
On path, inside path, and outside path will each allow tabs. Anything other than “clear out a pocket”
And the option is only visible when a single design element is selected, if you have multiple design elements and set them to full depth, they will have tabs, but those tabs wont be visible to turn off, to change the size or quantity or to move around, unless you select only one piece at a time, or combine all of the pieces into a single selectable design element (Edit>Combine)
