Inkscape has some laser Plug In extensions. You can download one from the J-Tech web site also.
the download had just finished installing. haha. going to test that as well. I do have access to a Windows computer at work, but wonāt be in a place where it can be plugged into the X-Carve.
Assume connecting to the machine would be required for best practice with PicEngrave apps?
PicEngrave can generate the gcode and it can be saved on a thumb drive and ran in UGS which is multi platform. It will be hard going back & forth for trial & error setting tests though. Or, I use one of these to generate the gcode and stream it with our PicSender. It works good.
Or, like Robert said, setup a Windows emulator on your Mac.
dang it⦠the pink one is out of stockā¦
I am trying the Inkscape/JTech option. Couldnāt make it do an svg logo, so just put my name as text, converted to path, then exported the file with basically default settings. Then used UGS to send it.
I saw ! haha. So apparently my S1000 and F300 was way too slow and burned things up.
Is there a recommended/typical intensity/feed speed for 3.8W users (or any laser)?
(still contemplating the Windows options, just would like to at least get the thing working before spending even more )
F300 & S1000 seemed to be a āsuccessā
I would assume the focus is what it should be? do I just spin the focus until it looks like itās smallest point? itās safe for me to touch the focus ring with my bare fingers with the laser on? Just watched this thing make a fireā¦
I guess ācommon practiceā is to just try different speeds on scrap wood until it does what it should?
There are so many variables like the type of wood your burning, so you will just have to experiment with the settings. J-Tech has focusing instructions on there web site here: https://jtechphotonics.com/?p=2602
very helpful. have done a few tests and am starting to get pleased with the quick results as well as seeing the limitations without paying for a PC or additional software⦠add to next christmas listā¦
Also a OSX person. My perception youāre doing 3D carving. How? Thanks.
My error, it doesnāt fit this thread.
So, the only way to laser more than just a stroke path is to use PicEngraver Pro + Laser?
Or another option?
The only way I can think to āfake itā would be to throw an offset path inside my shape, however many itād take to fill the area.
just tested the cube for a visual (should be all filled in)
EDIT: Though PicEngraver is only $90, being a Mac user, buying a PC or a Win10 license to run Bootcamp starts adding to the price a bit⦠If PicEngraver is the ONLY option to fill a shape, I do have remote access to my work computer (a PC) and could buy the program there and send gcode back and forth testing (just thinking out loud).
working on figuring out that āifā part!
Yea, Iāve done the Inkscape/GCode export to UGS, thatās how Iām burning now. Iāve tested LaserWeb3 (looks to do the same thing as Inkscape/UGS). Didnāt know Carve also controlled lasers.
I also tried to download PicLaser on my PC at work and exported the Code and when opened in UGS, the āvisualizeā just shows:
Can the Visualize not be trusted?
The Laser Control command should be a S. Unless you use a Z with min/max depth values, the visualizer will not show anything other then just a X&Y axis plane.
The Laser Off Command should be set with a S0.
Edit: The Pixel Resolution setting determines the step over & step ahead for the X&Y axis moves in the gcode file. It should be set based on the laserās burn like width, so they lay down next to each other without overlapping each other or leaving gaps between them. If any other setting than .01 (inch) or .254 (Metric) PR is used, the image will need to be resized in the editor to ensure it will engrave the same size as the original image.
There is a Tutorial PDF button in the Help Menu.
So the Visualize in UGS will NOT show anything real? I understand limited options on the demo version, but was hoping to at least be able to test it to see if itāll do what Iām trying to accomplish before purchasing.
I set all settings like the PL PDF showed for a starting point, and UGS Visualize still shows just a polygon. (using JTech 3.8w laser on 1000m X-Carve).
Is there something Iām missing or is this common?
(my art file was made in Illustrator, then exported and saved at 300dpi so it would be hi-res. Only ~4"x2" overall size)
The UGS visualizer does not recognize S commands, so the view will only be a X&Y plane. Change the Laser Control Command to a Z and the Max Laser Value to a -.125 and generate the gcode again. Load it in UGS and and rotate the visualizer to an isometric view plane (if that is possible) and you will then be able to see the depth variances based on the shades in your image.
In the PicLaser image editor there is a Preview Gray Scale selection that gives you a general idea what your laser photo engraving will look like from a color image. I use it quite often when Iām editing an image. Nothing is perfect because there are so many other variables that effect the laser photo engravingās outcome like your focal point size, Pixel Resolution (step over), feedrate, min/max laser power values and the material your engraving on.
There is always a Trial & Error period for each user before they achieve any successful results. There is nothing seen in a gcode visualizer that will help with this process either.
you should also check out some YouTube videos about raster laser engraving with Inkscape. there are some good resources out there. like this one.
you can also check out this Inkscape extension from the same software as F-Engrave
http://www.scorchworks.com/LaserDRW_extension/laserdrw_extension.html#download
Thanks. I like that LaserDRW extension, allowing to handle raster laser stuff on a Mac. Guess need to see if thereās a way to take that .LYZ file to Gcode on a mac. Looks like the LaserDRW software can export g-code, but looks (of course) to be windows software. Let the googling begin
(I know I know, CNC world means Windows. Just hate spending more money right now and running two setups, so looking through options)
Installed this raster to laser option for Inkscape. From visualizing the results in UGS, it looks to be doing what I think it should. Hopefully can get out to the machine soon and give it a test and see what happens.
Just updating my results for other folks like myself (Mac user trying to live a laser lifestyle)
Raw Easel - Just uploaded SVG to Easel. Set my bit size to match the Jtech 3.8W specs (.014"), and ran at 100in/min
Converted Easel - Followed these step by step gcode-depths-to-shades . Similar result
1px, 5px, 10px - Used the R2L plugin for Inkscape. Tried a few different resolutions to compare
Jtech - Used the Jtech Inkscape Plugin . Works, just only does paths, doesnāt do fills
Grayscale - big bust. using the R2L plugin as before, just with a different setting
So far, the 5px Raster 2 Laser option has proven to be the best, just need to tweak power and speed to get the burn right.
