What is the best way to clean a fan
Hey there,
Me I used to use a can of compressed air and use like a tooth pick to keep the fan from spinning, not sure if it would have damaged the fan. Now I use a pancake compressor with a low PSI and still use a tooth pick to keep it from spinning. If you remove power and open it up you can also use a toothbrush that works good too.
Hope that helps
Thank you Roger.
That’s really helpful.
