I just used the two flute 1/8 end mill and standard settings from easel for my first cut in aluminum, work great made my first part and no problems. there is a search function for more information if you are wanting to do more that just a simple cut.
This is a must, as in something that keep the whole sheet down - otherwise it WILL lift.
I have cut 1mm alu sheet in one pass, worked fine for me. 2mm bit at 12ipm at full depth.
