How to cut only the outline of a SVG
We are trying to figure out how to convert a JPEG to an SVG and only cut the outline of the object. Is there a way to do that? Thank you!
Do you have Inkscape?
I’ve used this to convert images to SVG https://image.online-convert.com
I use convertio an on line converter then I use the offsetter app in Easel to create the outline. Yous set it to the distance you want.
Google Chrome has a Converter, JPG to SVG, give it a try. Good luck.
