is there a way to detail cut and then use a straight bit to cut out piece on same path as detail cut
I don’t see why not, can you share the file?
File-Share-Shared with Link-
Copy Link then make sure you hit SAVE
paste link in forum
Russell
Yes, but you can not use Easel 2 stage routine for this as this require rough first, detail last.
- Make your overall design
- Duplicate this so you have two individual project files or (work file)
- Define for each project the cut rules (Outside/on path/inside of path or whatever, + bit geometry)
- Now you can use either of the two (or multiple more) in whatever order you need.
If you change bit during this sequence you need to re-zero Z to establish correct Z-level.
