How to import from Vcarve to Easel Pro
I am using the trial version of Vcarve. I have been trying to download some sample projects in Vcarve and send them to Easel pro.
Can someone tell me the complete process? I thought that I sat up the post processor correctly, but I keep getting errors in Easel Pro.
I would save the file in a DXF , STL, or SVG format from V carve. Then open it up in Easel. The tool with the Arrow pointing to the right will open up a window to select the format.
Hello,
To transfer projects from VCarve to Easel Pro, ensure you’ve installed the Easel post-processor in VCarve. Save your project in a compatible format (e.g., DXF, STL, or SVG). Then, import the file into Easel Pro using the “Import Gcode” option and select the downloaded post-processor. If errors persist, double-check the post-processor setup and consult the Easel Pro documentation for troubleshooting tips. red humana grupo éxito
Best Regards,
James Keen
