TimtheTractor. (1).stl (137.6 KB)
I design using tinkercad, which can make STL Files of the design.
file attached. Can I import them To Easel & incorporate them into my workspace?
Thanks in Advance
Chris.
To work with STL files you have to use Easel Pro. The standard Easel will not import them.
@ChrisHoffman Your design isn’t really a 3D design in terms of CNC. No need for the STL. Export from TinkerCAD as an SVG, and you’ll be able to do what you want in Easel.
Thank you so much.
