how do I set machine where I can make multiple copies all one after another
If you are cutting multiple items from the same piece of stock, then copy and past the required shapes to cut them all out. If the work is carving on individual pieces of stock, then Phil’s suggestion is the way to go.
Why was this flagged? LOL
I guess that makes sense, I still found it insightful.
I guess that I just don’t quite understand flagging.
All you have to do is double click on it and it will show up.
What’s the point??
And yes, is a bit insightful.
