How to make xcarve select a 1/8th mill to cut out the shape
hi
how can i make my xcarve select the 1/8th mill to cut out the shape when using 2 different size milling cutters.
i need the 1/16th mill to cut some of the detail work after the 1/8th mill has carved out the bulk of the project.
Then I want to cut out the actual shape but it keeps selecting the 1/16th mill and this then increases the total time
I have the cutout operation as a separate workpiece after I do the two-stage rough + detail carve on the first workpiece.
Hi Kimberley
thanks for the quick reply
You can probably guess I’m new to CNC work, I’m not quite sure what you mean by having a separate workpiece.
I just have one board and using 2 different size mills but I want the 1/8th mill to cut out the shape but I cant make it use that it just goes to the 1/16th mil and this is making it take a long time to carve.
At the bottom of the screen, there is an area to add a workpiece. That way you can keep all your Easel files related to one project in the same Easel “file”.
Hi, I have opened up a 2nd workpiece by clicking on the plus sign, then I went back to the original draw cut the boarder then pasted it into the 2nd workpiece. So now I cut the drawing on workpiece 1 and when that’s finished click on workpiece 2 to cut the boarder to release the project out of the board. Have I got that right. Also do the 2 drawings line up ok .
Sorry for the long post and thanks for the advise
I actually usually do my design in one workpiece, then I use the “duplicate” function to make a copy. Then I delete the outline from one workpiece, and the design from the other. That way I know they are all lined up correctly.
Hi, this seems a better way than copying and pasting, thanks for the tip
