I’m near the end of my X-carve assembly at the point where I need to install the limit switch actuators using the “Post-Assembly Insertion Nuts”. I have two problems.
The photos do not clearly indicate which face of the post-assembly nuts should face out after they are inserted into the slide. Is it the side of the nuts with what look like little spring tabs?
I have no clue as to how to insert the nuts without disconnecting the makerslide. Are they supposed to be forced in in some way? Or do I really need to disconnect the slide?
Note: And IF the only way to insert them is to disconnect the slide(s), then I think the instructions should have said that MUCH earlier in the assembly process because it seems like it’s going to be a hassle to do that this late in the assembly process.
