I’m building a circular table top out of wood using three 120-degree segments of a circle. In the past, I would have cut them using a table saw - and a lot of trial and error. I would think that the X-Carve should be able to cut these with perfection, every time, all day long. I’ve been trying to figure out how to design “pie slices” in easel for a couple of days and I’m stumped.
I have created circles in Easel, then overlaid zero-depth shapes to create the slice, but when I ask for an outline cut I only get the 120-degree arc of the circle, not the entire slice. If I set the circle to a fill cut, I lose the entire slice, but that’s the inside-out version of what I’m looking for. If I set the other shapes to cut outlines I end up with the entire circle.
I’m sure I’m missing something simple, but I can’t figure out what. Any ideas?
