How would you draw this?
I want to draw in 1/4" slots into this piece and be able to cut them with a 1/4" flat bit if possible. What is the best way to do this Easel? See attached pictures that I hope will help show what I need.
Thanks!
I believe I have it figured out using the line tool. I need to do a trial and error cut to see if I have the 1/4 lines right.
Admin, you can delete this if you like.
The line tool is correct. Make sure when you set up your cut to select “On The Line”. Vice Inside or Outside the line.
You can also use the box tool and set as fill define the w x l x d. Cut on inside
Don’t. It’s a good post for others to learn from.
