A new problem has got me stumped again. I can only pick one type of bit router to route with. If I try any other bit only a few holes are routed. In the attached picture if I use the bit shown everything looks good. But try any other bit only a few holes show up.
This has 100% to do with the design is too small for that 1/8" bit to fit into, you can either enlarge the design, or use a smaller bit…
Note:vbit toolpaths are calculated differently, using their angle to determine the depth and a vbit will fit into any design size because the tip is a miscoscopic needle point…
