Thank you BrianSaban for your fast reply and helping me in solving this issue.
This is not my actual board but this is for showing you my errors.
I removed the wire is solder in the pins and return every thing as original.
I fit the gSheild to Aruino correctly.
Only Z axis is working, also i tried to connect the Y-axis to Z and it is working, even the X-axis when i connect it to z-axis it is not working
Yes issue soldering the gshield
yes stepper motors all work when plugged into Z but not if plugged into X or Y
what you mean Have you tried raising your X and Y potentiometers?
Finished now
I bought a new gSheild and its working again fine and i solder it correctly.
But i bought also a laser from which is at this link enter link description here
i do not know know to connect some wires i feel the description is not clear regarding wiring. Can you help me Phil
