We use cookies to personalize content, interact with our analytics companies, advertising networks and cooperatives, and demographic companies, provide social media features, and to analyze our traffic. Our social media, advertising and analytics partners may combine it with other information that youâve provided to them or that theyâve collected from your use of their services. Learn more.
What software do xcarve users recommend for importing dxf files? I want to make patterns and need to know what a good program or software I should use? Thank you
A more likely cause is loss of step along the Y-axis as one (inferior) stepper driver drive two motors, so each Y-stepper only have half the power your X-stepper have. (which also isnât run at its potensial due to driver limitations)
Another possible cause is overheating of the stepper driver, this will cause sudden âdrop-outsâ as the over-temp kicks in.
In your case my main suspect is loss of step due to lack of power.
I had this problem using Easel, I now use Vectric Desktop and CNCjs and no longer have the problem. I did try an Easel project the other day and bang it did it again so unfortunately I think there may be a problem with easel
U OK I just got back on sometimes it glitches sometimes it doesnât I started it right up the motor is cool and I try to just move it around with the machine controls:
I go plus on the Y at 1 inch fine negative fine
.1 of an inch positive fine negative fine
. 01 positive fine negative not good at all ⌠that machine make the noise to move but stays in one spot!
Have you played with your potentiometer? I ran a shield for a long time and dealt with similar issues that either come from not enough amperage being called by the pots, or too much causing temporary shutdown of the drivers. Either way, you should be familiar with the potentiometer in order to get that setup running correctly.
A better, longer video would maybe help diagnose, but your stepper pulley and the v-wheel are moving with each step from what I can see.
I do suggest that you replace ALL pulley set screws with socket head cap screws and use blue Loctite on the threads. This is an absolute necessity IMO.
4 sec is the most it will allow me to post. butâŚ
it is showing that I am clicking on the y axis button to return the head to me in the increment of .01 and it try to move, but is stuck. If change the increment to .1 or 1 or will move in any direction. But when put in âmicroâ movement .01 or .001 it will not move in the negative y direction
So I talked with customer for a long while and we came to the conclusion that my G-shield was bad. They had me switch the x and y wires and try to recreate the problem on the x axis. If the problem stayed on the Y axis it could be a wiring issue or motor problem. If the problem moved to the X axis it was a G-shield problem. My problem moved to the X axis. So I ordered the new x-carve controller and extra wire for the second motor. The machine runs sooo sooo much smother now, with the x-controller! Thanks for all the help!
