I have some files that are supossed to be gcode. they have an ext of .tap how can I tell what they will cut. I gues what I am asking is there a way to visulize the file
table_1_250EndMill.tap (158.3 KB)
I use Camotics to view g-code.
Okay then my next question is how do I make sure the feeds and speed are going to work? I dont know what post processor it is set for. Or is there something I can open it in to manipulate the material thickness and speeds?
You can use any text editor. Feedrates are easy to change. Material thickness is a different story…not impossible, but very difficult.
Ok, I ran the file last night in easel the feed rate and cut depth were both to fast. I would like to cut them both by half, but have no clue what i am looking for in the code.
Depth of cut is difficult to edit in a text file…adding additional passes will require a huge undertaking (depending on the piece being cut).
Changing feedrate is as simple as finding the FXXX (where X is the value of inches or mm per minute) and replacing all instances with your new feedrate.
T1M6
G17
G0Z0.8000
G0X0.0000Y0.0000S12000M3
G0X5.9503Y-10.1309Z0.2000
G1Z-0.1833F30.0
G1X6.1595F100.0
X6.1599Y-10.1250
X6.1590Y-10.1112
X6.1561Y-10.0970
X6.1510Y-10.0828
So lines 6 & 7 are feed rates, it looks like the one I need to change is line 7 and then do the same through the whole file
List of free/opensource previewing programs here: Shapeoko CNC Router, Rigid, Accurate, Reliable, and Affordable
thanks, I reduced the speed and it made a big difference.
