I need tips to carve granite plaques with XC
Hi
Anyone have you try granite stone carving I need shallow depth carving just surface I try but not
getting success. I face lot of vibration in Z axis in top and bottom sometimes I seen my z axis bottom v wheels get loose often while try to carving. I agree granite is hard but just surface it is possible. any upgrades can I get success.
I already try endmills, diamond V bits. V bits taking very long time if alphabets have more than takes long time. I have makita router I want make possible. anyhelp I appreciate.
Do a search for ‘granite’. You’ll find a few threads on the subject.
Atonwa did some stone work on his Shapeoko: http://www.shapeoko.com/forum/viewtopic.php?f=7&t=7544&p=59484#p59716
I was thinking that maybe if you could hold the material X and Y axis with some straps and then put it on a piece of foam so that you could get pressure on the bit and yet z height flexibility it might work for shallow engraving.
I don’t imagine that any material would be flat enough to get the same shallow height for the bit to just barely skim the z axis.
If the surface is irregular you should cover it with aluminum foil and use a probe first, or build a touch probe and probe it before cutting — list of designs here http://www.shapeoko.com/wiki/index.php/Touch_Plate#Touch_probe — bCNC supports probing a surface to map a G-code file to it.
I agree no material is flat specially in woods and stones but I will use granite which surface is even and flat
I not get your idea about foam. Did you telling put a thin foam board onto the granite and carve?
I’ve never done anything like this so it’s just like my crazy idea.
By using foam I mean to put the granite on. Since you are only etching. To kind of push the material into the bit and yet have a little cushion. A very loose foam like cushion foam. But it seems that you would have to make sure you set it up so that the material doesn’t move in the X or Y position. Are you using like a rounded diamond bit.
Many thanks for reply. I was try Sharp V bit similar like this https://www.inventables.com/technologies/bit-set-for-v-carving
