I need your help, my friends
I need your help, my friends.
I am mounting my X-carve 1000 mm, today I noticed that I have the Y2-axis and Y1-axis cables switched and it makes each motor go in the opposite direction.
What can I do to correct it?
Thank you my friends.
António Guerreiro
Are your motors fighting each other or is the whole assembly moving in the wrong direction?
If they are fighting each other simply swap the red and white wires on one motor.
If the assembly is going the wrong way, configure your machine with easel.
Hello @ErikJenkins. The engines are fighting each other.
Thanks for the suggestion, I’ll soon change the wires.
Great week.
António Guerreiro
the Y motors are supposed to turn in opposite directions of each other. Other wise when mounted they would be working against each other.
