I searched for this in the forums, but couldn't find it. Acrylic buildup on bit
I broke yet another bit trying to cut acrylic. It was going fine but the acrylic kept building up on the bit. Then the bit broke :confused: Is this just going to happen or is there a way to safely get the acrylic buildup off of it while in operation? The bit I used was a 1/16 fish tail 2 flute.
The build-up could be caused my melted acrylic, faster feed rates and shallower cuts will not allow so much heat to build up and melt the acrylic.
That being said, I have not cut much acrylic…just a few pieces.
There’s no doubt in my mind that friction is the culprit. I messed up a good sheet of mirrored acrylic trying this :frowning:
I went with the default depth per pass and should have made it more shallow. I wonder if the bit I chose played into enabling the buildup. The design had fine detail so I tried to go with a small-ish bit. Ugh, I can’t afford to keep breaking all these bits (and acrylic) while I learn things the hard way :stuck_out_tongue: Thanks Erik.
Bring the spindle speed down, increase the feed rate and do shallow cuts with a bit that can produce big chips.
The build up is purely heat melting the material onto the bit.
You may switch to down cut bits. That’s what I did for any Plastics. Lot better results.
http://www.ebay.com/itm/381313362014?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
You might also try cast acrylic. I’ve been cutting it without a problem - it is much more tolerant of the heat and melting issues than extruded acrylic.
Thanks for that link. I just bought that, and a 1/16" one as well.
