I have a LOT, I mean a lot of files stored. Many of them are blank/empty, just where I might have had easel started up and quit for whatever reason or was goofing around with settings.
It’s a bit unwieldy to open up each file into easel, check it out, reclose it and then delete it from the list. Is there any way we could have a small image preview of the easel file, and/or a different way to order the files? If we were able to order them by name, this would alleviate some issues as you could just avoid most of the untitled ones.
Any assistance would be greatly appreciated. Thanks!
I mostly use following preview application. It gives thumbnails what ever you have before viewing. You may like it. At least you know which picture goes to easel. You must download two files for either 32 Bit or 64 Bit.
