Vectorizing failed: InvalidSignatureException: Signature not yet current: 20181012T135642Z is still later than 20181012T135637Z (20181012T135137Z + 5 min.). Try re-uploading the image or refreshing your browser.
Have you call customer support??
Does other projects work? Is this an isolated project problem?
yes , they couldn’t understand my problem, nor could they explain things at a level of understanding . It happens when I try to trace on my HP . I am thinking a update is the problem
Did you try restarting your computer?
have you checked the system clock? if there is a mismatch between the system time and the time reported by the browser this can cause symptoms like this.
I second Kenneth. Check your computers clock. that was what solved the same problem for me.
I never did get it to work, got a new CPU now, so it works fine.
