I have imported a G code file from fusion360 into Easel using the Easel Post Processor file for Easel. So far so good, but on import the image for cutting is outside the workspace in Easel? Have tried to relocate image in Easel but result is the same, why?
You set the gcode in Fusion. Nothing you do in Easel will change what the imported gcode says.
The preview in Easel only shows the extent of the gcode, it will not show your stock. This confuses many people.
Thanks Neil!
