Is there an option or a process to import ALL of the bits available in the Inventables store for the X-carve into easel so I can simply pick by color or profile?
I could be wrong but I don’t think the settings change based on bit type, just bit diameter. Like a 1/8" ball end mill would probably generate the same toolpaths in Easel as a 1/8" straight. So as Robert says, you need to either measure your bits to get the exact diameter or go with the nominal and understand the cut may not be the exact size.
Thanks! I was thinking too much again.
What part do you measure? The shaft right ?
The cutting part of the bit. For instance my 1/32" bit has a 1/8" shaft but the bit is reduced down to the cutting portion.
