Hi
When I import a dxf into easel that is just a line drawing it loads immediately, but when the dxf is a word generated from a font the import just says loading indefinatly.
Is there something Im missing that is preventing the word from loading?
Hi
Try using the on line converter Convertio. Convert it to a SVG and then import it
You may have to “explode” your text into its little component lines.
Thank you. I will try this next time and post my results
