I am a new X-Carve user and have only been able to make a couple of things while I learn and work out the 'kinks;. I also have Vetric VCarve software that I enjoy designing on as it has so much more potential and ability to do much more than just Easel. I recently upgraded the version to 11 from 10.5. However, now I cannot import my toolpaths/g codes from Vetric as Easel says that there is a ‘syntax error’ in the code. I reverted back to the earlier version and was able to import the g code without any problems. I have also downloaded the post processor to the file as instructed but to no avail.
Vetric’s V11 software now includes that post processor found in the Easel guide pre-installed but re-named as “X-Carve” you’ll need to select one of these and apply it, then you can save the gcode and it should load without the syntax error…
As for the post processor, I have already selected the X-Carve *gcode - inch. I have gone into the Machine configuration and made the changes. Same issue occurs.
And did you try the supplied post processor from Easel’s site using this little folder at the bottom of this photo?
IF that doesn’t work another option to TRY is the “G-code” generic post processors to see if that’ll work… If I had the paid version of Vcarve I’d try it for you, but since I’m just messing with the trial one I can’t verify which one of these will resolve your issue…
