Increase easel workbase size
we have an x carve set up for 800mmx800mm (31 inches) but Easel only allows work pieces up to 300mm square (12 inches). is easel able to be set up for larger work peices?
Go to the “Material” menu option. Your X and Y values are probably set to 12 (that’s what it defaults to), you put in 31"x31" there you should be set.
