Independant shape carving
I’d like to see the ability to have shapes carved independently of other shapes on the workpiece. Specifically this refers to filled paths.
If you look at the example below, you can see that the two ellipses are treated as a single filled volume when the tool paths are calculated (vCarve toolpath shown). I’d like the ability to set a flag on the shapes to have them carved independently of other volumes.
The goal with this feature request is to be able to add features like textures that require overlapping geometries and need to be carved independently of other geometries.
This can be solved by using different workpieces, but that isn’t an ideal solution, just a work-around.
