Input size to cut
Hi, can I use Easel to put in exact size in mm to cut or do I need to use another program to size my cuts and then import to Easel? For example if I want to cut circle that is 26 mm.
Thanks Oskar.
you can make whatever size you need
Thanks a million :+1:t2:
