Good afternoon all
I have a question… does anybody know how I get radio controlled aircraft plans in to x carve so it will cut out the parts instead of cutting each piece by hand
Thank you.
Good afternoon all
Thank you.
Scan them and import them.
Trace the parts on white paper and include a square in your unit of choice. In., MM, or CM. Use the printer/scanner to scan the paper and save that as a PDF. Import the PDF into a cad program and adjust scale by checking the dimensions of the square, and save as a DXF or compatible Easel format. Import the DXF and convert to gcode. Load the code…and cut away. I do this all the time when I want to copy existing parts I want to make in lieu of buying them from somebody else.
Hi Martin
Thankyou very much for that detailed description, very much appreciated.
I just cut about 50 parts out of a very expensive sheet of carbon fiber. These were to cover holes under the hood a custom show truck. In our case we used masking tape and marked it up on the truck, peeled them off, stuck it on cardboard then I cam home and redrew all the parts in easel. I cut them out of MDF first to confirm the shapes. Worked like a champ.
