Any body know any good bits to get fine detail and small Text
You can use a vbit.
Any angle vbit can carve very fine detais, the key with vbit carving is to surface the workpiece on the cnc.
For example this is a 6" catch all tray and because the pocket essentially makes the flattened the surface that i vbit carved into, carving the tray pocket functioned like surfacing and made that surface both flat AND perdectly parallel to the spindles plane of movement in Y&X axis.
Without a flattening operwtion like this it can be difficult to have perfect vbit carves.
If you’re looking for more details, I use tapered cutter instead of your typical v-bits/
Find’em on amazon
This topic was automatically closed 180 days after the last reply. New replies are no longer allowed.
