Anyone know why the box app doesn’t cut the joints deep enough to line up?
Did you set the material thickness in the app, not just Easel main screen?
How do i set the thickness in the app? The only selections it allows me to make are (Width/Height/Depth). When i get ready to carve i set the thickness of the material to the appropriate size using the calipers.
Did you change your material after using the app?
I think you need to choose your material thickness before designing the box with the app.
If you change the thickness later the notches will not be changed.
