If I accidentally delete something in easel and then close the window, it saves the project and when I reopen it, I can’t undo.
Is there a way to roll a project back in time?
My error of course, but I still have to ask.
Thanks
Thanks
You could export the project each time prior to making changes that you may want to undo.
{:0)
Brandon Parker
You could occasionally duplicate the workpiece and use the new one for additional changes, effectively using the workpieces as a timeline.
Other than a manual method like this, no easel doesn’t have a change timeline the way fusion360 does
